RCU Forums - View Single Post - Eagle Aviation One Design Build
Old 10-31-2011 | 01:35 PM
Tony Hallo
Default RE: Eagle Aviation One Design Build
I had the day off work so I put ina shift in the man cave. The cowl will be mountedon 4 aluminum pins, the pins will be cross drilled and tapped for 4-40 screws. Slide to cowl on the pins and install the screws, no fiddling around lining up screw holes. I left a small flange on the back of the pins so if the glue joint fails the pin will not pull out. I also added grooves to increase the holding power.
ID:	1681032   Click image for larger version
