Ken Lambert does the same conversion also.
<table border="0" width="100%"> <tbody> <tr> <td height="36" width="73%"><span class="main_text">
<span class="style13"><font size="5">$439.95</font></span></span></td> </tr> <tr> <td><span class="main_text">Announcing the new <span class="style5">BME G90 Engine</span>... the first quality/performance gas engine this small ever made! The .90 engine is the same size and weight as the .60 and .75 so why not go for a .90 get morebang for the buck? This new engine is a gas conversion from a
SuperTigre .90 glow engine, so it comes with all the history and reputation of the SuperTigre engine line, combined with the engineering expertise of BME Engines... Quality you can trust with robust construction that will last a lifetime.The G90 runs on
32:1 gas/oil mix, so it's economical to operate. 1 ounce will run for 3 minutes at full power. The fuel savings alone will pay for the engine in a short period of time. Plus, there's no oily mess to clean up (who likes to wipe all that oily film left from glow fuel anyway?) </span></td> </tr> <tr> <td></td> </tr> <tr> <td><span class="main_text">You get a custom built
BME crankshaft, connecting rod and piston (needle bearings for gasoline/oil mix). A custom modified crankcase and housing from BME was also in order for optimum gasoline operation.Because we use a
Zama pump carburetor, you can now mount your fuel tank anywhere... the carb will pump fuel just like all other gas engines, much better transition and no dead sticks. Experience the ease of
electronic ignition... easy to hand start with no glow plugs or glow drivers, and, no field box full of support equipment. Get no weight penalty since the engine weighs about the same and the ignitionwith battery weight is offset by the reduced fuel tank capacity required. The G90 is supplied with a stock muffler but you can use any aftermarket muffler that works on the SuperTigre 90 glow engine.</span></td> </tr> <tr> <td>recommended props 13 x 6, 14 x6</td> </tr> <tr> <td><span class="main_text">Yes, no more rusty bearings as with glow engines (gas and oil are natural lubricants and do not absorb moisture from the air as glow fuel does.) That's right... more power and a larger carb, electronic ignition and special BME modifications all add up to an engine that has no power loss and is like a
.60 size plane on steroids!</span></td> </tr> </tbody></table><table border="0" width="100%"> <tbody> <tr> <td height="36" width="73%"><span class="main_text">
.60 size plane on steroids!</span></td> </tr> </tbody></table><table border="0" width="100%"> <tbody> <tr> <td height="36" width="73%"></td> </tr> <tr> <td></td> </tr> <tr> <td></td> </tr> <tr> <td></td> </tr> <tr> <td></td> </tr> <tr> <td></td> </tr> </tbody></table><table border="0" width="100%"> <tbody> <tr> <td height="36" width="73%"></td> </tr> <tr> <td></td> </tr> <tr> <td></td> </tr> <tr> <td></td> </tr> <tr> <td></td> </tr> <tr> <td><span class="main_text">
