Any one running the BME .90??
Old 11-04-2011 | 05:14 AM
Steve's Avatar
My Feedback: (54)
Default Any one running the BME .90??
I'm going to pick one of these up and install it in a Sig 1/5th scale Cub. Just checking to see if there is any info on the motor. Thanks.
Old 11-04-2011 | 05:16 AM
Default RE: Any one running the BME .90??
Lots of people using them. It's a very good little engine.
Old 11-04-2011 | 05:31 AM
Ken Lambert does the same conversion also.
<table border="0" width="100%"> <tbody> <tr> <td height="36" width="73%"><span class="main_text"> <span class="style13"><font size="5">$439.95</font></span></span></td> </tr> <tr> <td><span class="main_text">Announcing the new <span class="style5">BME G90 Engine</span>... the first quality/performance gas engine this small ever made! The .90 engine is the same size and weight as the .60 and .75 so why not go for a .90 get morebang for the buck? This new engine is a gas conversion from a SuperTigre .90 glow engine, so it comes with all the history and reputation of the SuperTigre engine line, combined with the engineering expertise of BME Engines... Quality you can trust with robust construction that will last a lifetime.The G90 runs on 32:1 gas/oil mix, so it's economical to operate. 1 ounce will run for 3 minutes at full power. The fuel savings alone will pay for the engine in a short period of time. Plus, there's no oily mess to clean up (who likes to wipe all that oily film left from glow fuel anyway?) </span></td> </tr> <tr> <td></td> </tr> <tr> <td><span class="main_text">You get a custom built BME crankshaft, connecting rod and piston (needle bearings for gasoline/oil mix). A custom modified crankcase and housing from BME was also in order for optimum gasoline operation.Because we use a Zama pump carburetor, you can now mount your fuel tank anywhere... the carb will pump fuel just like all other gas engines, much better transition and no dead sticks. Experience the ease of electronic ignition... easy to hand start with no glow plugs or glow drivers, and, no field box full of support equipment. Get no weight penalty since the engine weighs about the same and the ignitionwith battery weight is offset by the reduced fuel tank capacity required. The G90 is supplied with a stock muffler but you can use any aftermarket muffler that works on the SuperTigre 90 glow engine.</span></td> </tr> <tr> <td>recommended props 13 x 6, 14 x6</td> </tr> <tr> <td><span class="main_text">Yes, no more rusty bearings as with glow engines (gas and oil are natural lubricants and do not absorb moisture from the air as glow fuel does.) That's right... more power and a larger carb, electronic ignition and special BME modifications all add up to an engine that has no power loss and is like a .60 size plane on steroids!</span></td> </tr> </tbody></table><table border="0" width="100%"> <tbody> <tr> <td height="36" width="73%"><span class="main_text"> <span class="style13"><font size="5">$439.95</font></span></span></td> </tr> <tr> <td><span class="main_text">Announcing the new <span class="style5">BME G90 Engine</span>... the first quality/performance gas engine this small ever made! The .90 engine is the same size and weight as the .60 and .75 so why not go for a .90 get morebang for the buck? This new engine is a gas conversion from a SuperTigre .90 glow engine, so it comes with all the history and reputation of the SuperTigre engine line, combined with the engineering expertise of BME Engines... Quality you can trust with robust construction that will last a lifetime.The G90 runs on 32:1 gas/oil mix, so it's economical to operate. 1 ounce will run for 3 minutes at full power. The fuel savings alone will pay for the engine in a short period of time. Plus, there's no oily mess to clean up (who likes to wipe all that oily film left from glow fuel anyway?) </span></td> </tr> <tr> <td></td> </tr> <tr> <td><span class="main_text">You get a custom built BME crankshaft, connecting rod and piston (needle bearings for gasoline/oil mix). A custom modified crankcase and housing from BME was also in order for optimum gasoline operation.Because we use a Zama pump carburetor, you can now mount your fuel tank anywhere... the carb will pump fuel just like all other gas engines, much better transition and no dead sticks. Experience the ease of electronic ignition... easy to hand start with no glow plugs or glow drivers, and, no field box full of support equipment. Get no weight penalty since the engine weighs about the same and the ignitionwith battery weight is offset by the reduced fuel tank capacity required. The G90 is supplied with a stock muffler but you can use any aftermarket muffler that works on the SuperTigre 90 glow engine.</span></td> </tr> <tr> <td>recommended props 13 x 6, 14 x6</td> </tr> <tr> <td><span class="main_text">Yes, no more rusty bearings as with glow engines (gas and oil are natural lubricants and do not absorb moisture from the air as glow fuel does.) That's right... more power and a larger carb, electronic ignition and special BME modifications all add up to an engine that has no power loss and is like a .60 size plane on steroids!</span></td> </tr> </tbody></table><table border="0" width="100%"> <tbody> <tr> <td height="36" width="73%"></td> </tr> <tr> <td></td> </tr> <tr> <td></td> </tr> <tr> <td></td> </tr> <tr> <td></td> </tr> <tr> <td></td> </tr> </tbody></table><table border="0" width="100%"> <tbody> <tr> <td height="36" width="73%"></td> </tr> <tr> <td></td> </tr> <tr> <td></td> </tr> <tr> <td></td> </tr> <tr> <td></td> </tr> <tr> <td><span class="main_text">
Old 11-04-2011 | 05:49 AM
Steve's Avatar
My Feedback: (54)
ORIGINAL: Tired Old Man
Thanks. Tom is going to put me one together. Hopefully I'll have it in the next few weeks.
Old 11-04-2011 | 08:55 AM
av8tor1977's Avatar
I love mine. I've had it for a a couple of years or so. Runs great!
AV8TOR
Old 11-04-2011 | 10:57 AM
SpinnerRow's Avatar
Why not go with the JBA 15cc for half the price? Lots of people seem to like them as well.
Old 11-04-2011 | 11:18 AM
Less than half the lifespan as well.
Old 11-04-2011 | 01:09 PM
Steve's Avatar
My Feedback: (54)
I have to say, I am a BME fan. I've ran several of there engines over the years starting out with the 102. I still have a 58, 105, and 110 that have been excellent engines and I realy like how Tom treats people. Can't wait to get the .90. I've got a MA 13X6 that I'll try first. I think that will be a good prop for the Cub.
Old 11-04-2011 | 04:20 PM
One thing people don't know about BME. Tom, the owner, IS an engine man. Big time involvement with building auto racing engines. He's innovative, creative, and exacting. Some very good reasons to base purchase decisions on. You won't find any of those attributes with any of the Chinese RC engine manufacturers. I'll say that again, any.
Old 11-04-2011 | 05:30 PM
aussiesteve's Avatar
I am running a BME 0.90 on a Mojo, previoulsy it has been on a small Waco Bipe and a Cub. Try the 13" prop first by all means but you will most likely prefer the 14" for your cub.
THE BME 0.90 IS A GREAT LITLE ENGINE.
I have also run the Chinese 15cc's (RCGF 15 and JBA 15 as well as the NGH 17) and they are not a patch on the BME, not even close when it comes to real life performance. Don't be fooled by the "Spins xxx prop at yyy rpm" claims on how the others are sold.
Have a read through the threads on the others and you will see why NOT to buy anything from those "designers" People have a lot of issues with them in the range where they actually get flown.
Old 11-04-2011 | 06:18 PM
yes BME90 is great!  none Chinese brand can be compared with BME, because its origial is Super-tiger!
Old 11-04-2011 | 06:24 PM
They also tune easily and run well in the mid range (consistently and for quite a long lifespan). Maybe you could learn something about that Michael
Old 11-04-2011 | 06:36 PM
yes, thank you for your advice, but I face and know the distance, it is easy to say but really difficult to do. although Super-tiger product line is in China, but all of these machines were from Italy.
Old 11-05-2011 | 06:53 AM
mrbigg's Avatar
My Feedback: (21)
ORIGINAL: aussiesteve
What prop you running on yours? I have a Mojo 60 and I'm running a ST .90 on 0%, spinning an APC 15x4 wide blade. I tried a 14x4 wide and it didn't like it, so I threw the 15 on there thinking it wouldn't work out so good. I was wrong, works excellent. I have a CH ignition kit that I bought to use with this engine, hence the 0%. Still have to set it up.
Old 11-05-2011 | 04:32 PM
I'm running the APC 15/4W on the Mojo. It is about perfect for it. I used a 14/6 but found the same thing as you, the 15 is a much better "MoJo prop".
When the Engine was on the Cub, I also tried a 15/6 APC it worked fine for a Cub in scale flight but the takeoff rolls were a bit longer than ideal. the 14/6 was about perfect for general sport flying.
