ORIGINAL: FenderBean
I disagree about the programming, but like anything else if your used to jr then futaba will seem that way and if your used futaba jr will.
I Disagree!!
as you know about half the locals use Futaba and i did the vast majority of their builds/installs/setups the past many yrs so i've had extensive dealings with Futaba setup too, and it's nowhere nearly as straightforward and simple as JR
as far as Spektrum/JR, they aren't in the same ballpark IME. i've had 3 Spektrum module based JR radios with Spektrum receivers simply lock out and fly off, i've NEVER had a single glitch with a JR Dedicated 2.4 system (my 12x, others 9303/9503s) with JR receivers. it's like DeWalt v/s Black & Decker, they are both made by B&D, but DeWalt is quality, B&D is garbage.
