RCU Forums - View Single Post - chit chat thread
Old 11-08-2011 | 05:43 AM
  #251
Air Vaca
Default RE: chit chat thread
$200 to bl an mCPX! You gotta be kidding. The bloody motor is $20, esc$15, dunno about thesteve converter...that looks like less than a hundred. Is that bl tail, too?
Private chat rooms can be set up. I'm not sure how, but we set one up when we were getting the TechHead into production. I'm looking at putting a 3gm bl main in my Genius. I need to change the motor mout and revers th shaft as it's an HP03t [tail motor]. This is a different wind than the HP03s....the "T" is rated 8000kv and the "S" is 11,000. Sounds like the diff between "delta" and "wye" winding. The "T" may allow me to use the sock pinion. I've got all the stuff, except time. Oh, if you need the esc for your conversion, I have 2 or 3 NIP that I can off. I think I paid $10 ea for them.
Got the fireplace installed and it's heating. None too soon. Frosty outside this AM...about 27`F. I wouldn't mind 27`C but...
Now I need to hack up my brush pile to feed it. That should keep it for a couple of weeks, if I don't run into too much green wood.
regards,
Bill
