RCU Forums - View Single Post - Stinger 2
Thread: Stinger 2
Old 11-12-2011 | 03:22 PM
  #83
trainerjock
Default RE: Stinger 2
maukaonyx, my Stinger II also appears to have a little anhedral, but I think it might be optical illusion because of the shape of the fuse at the wing joint. If I place the plane on the becnch, the wings are the same height from the bench all the way across. The guys at the field even thought it has anhedral. At any rate, I will leave things as they are because this plane can do any maneuver I can handle and then some. I even had it in a hover for a very short time LOL. Thanks for the tip on the expo. My ailerons are very sensitive around center stick. I will give your expo settings a try.
