Heli fuel for plane
Yes...I have.
It doesn't really matter if it's heli, airplane, or even car fuel. What matters is the oil content, the nitro content, the oil type, and the quality.
For "most" 2 strokes (O.S., TT, Magnums) you want around 18% oil. I would never use less than 18% and am glad to use 20% for the extra protection.
As far as nitro content goes, anything from 5% to 15% is fine without making any physical changes to the engine.
The difference between heli fuel is that it's usually all synthetic oil, as opposed to a castory/synthetic blend. That means, no castor. If you end up running it a little lean, or storing the engine without after-run oil, the synthetic won't protect like the castor oil. I don't know how true that really is, but from my own experience, I'll ALWAYS use castor.
The disadvantage is that the castor oil makes a mess..
The fuel I use is a 80/20 blend of synthetic/castor... That is what I recommend.
