Heli fuel for plane >
Heli fuel for plane
Heli fuel for plane
Old 08-23-2003 | 02:12 AM
Default Heli fuel for plane
Just a question that suddenly pops up. Have anyone ever use heli fuel (for 2-stroke engine) to power a nitro plane engine? Can that works and will it cause any damages to the engine?
Old 08-23-2003 | 04:29 AM
Yes...I have.
It doesn't really matter if it's heli, airplane, or even car fuel. What matters is the oil content, the nitro content, the oil type, and the quality.
For "most" 2 strokes (O.S., TT, Magnums) you want around 18% oil. I would never use less than 18% and am glad to use 20% for the extra protection.
As far as nitro content goes, anything from 5% to 15% is fine without making any physical changes to the engine.
The difference between heli fuel is that it's usually all synthetic oil, as opposed to a castory/synthetic blend. That means, no castor. If you end up running it a little lean, or storing the engine without after-run oil, the synthetic won't protect like the castor oil. I don't know how true that really is, but from my own experience, I'll ALWAYS use castor.
The disadvantage is that the castor oil makes a mess..
The fuel I use is a 80/20 blend of synthetic/castor... That is what I recommend.
Old 08-23-2003 | 05:26 AM
For what it's worth, Cool Power's 15% Heli is the same as their normal 15% blend. There's just a different sticker on the bottle, and because it says heli shops can get away with selling it for a bit more. That's a unique case, though. Their 30% glow fuels are somewhat different blends as I understand it.
Brian's right, so long as there's enough oil there's no problem. It's largely marketing.
