RCU Forums - View Single Post - Pushrod Geometry
Old 11-15-2011 | 02:02 PM
rlipsett
Default RE: Pushrod Geometry
wait one second here I think the first picture is wrong. the arm should at center be parallel to the hinge line. That way when the arm moves it has equal up and down movement. the push rod should be 90 degrees or perpendicular to the hinge line. the second picture is right but it looks off because the pushrod is not perpendicular too the control arm
