RCU Forums - View Single Post - Pushrod Geometry
Old 11-15-2011 | 06:15 PM
rlipsett
Default RE: Pushrod Geometry
if the servo is in the fuse mount the control arm verticle up or down depending on positioning. run the push rod straight back 90 degrees to the control horn which should be straight back behind the servo arm. they should be inline
anything that is out of alingment creates torsion force which tries to break things. my rudder is a little off as you can see. optimally the control horn should be slid up more on the rudder so all things would be equal
ID:	1687167   Click image for larger version
ID:	1687168   Click image for larger version
ID:	1687169   Click image for larger version
ID:	1687170   Click image for larger version
ID:	1687171   Click image for larger version
