RCU Forums - View Single Post - aw-32
Thread: aw-32
Old 11-16-2011 | 10:49 AM
CRX Turbines
Default RE: aw-32
<div style="margin: 0in 0in 0pt"><span style="font-size: 9pt">Whether or not these oilswill workmightbe determined by some testing (assuming someone has a motor they don't mind experimenting with) but seeing that you have a new motor are you perhaps voiding the warranty by using a different oil than what is recommended byeverymanufacturer? Ifyou do experienceany issue with your motor and it becomes known that you were using a totallydifferent typeoil in the thing, I have a feeling you may have an issue getting your repair covered even if you keepup withthe required maintenance schedule with Kingtech.</span></div>
ORIGINAL: skydve76
ORIGINAL: marquisvns
KC is right, AW-32 has a much lower flash point if you compare the specs
glad you showed up, this is for my new k80f. can you oist some options I can use? what abou dte light?
