This is about as close as you can get (I think). I bought the panel ready starter and the power pack as shown in the two different links below, (be sure to get the charger as well). I then cut the power cables on the starter and installed quick connectors on both ends. That way if the battery goes dead on the starter, you can re-attach the cord to the starter and use your power panel, (if and when you get one). Sullivan also has about the same type of set-up available.
Hope this helps...
http://www2.omnimodels.com/cgi-bin/w...I=HCAP3200&P=7
http://www2.omnimodels.com/cgi-bin/w...I=HCAP0901&P=7
T.
