RE: CA Models ENVISION
Heres a few pics, with some dimensions that my U/C bolts are locate at. As you'll see from the pics the front 2 bolts in each leg could easily go back a bit. I got lucky!
The only things I changed in the arf was the cahinges, I used radio south ca hinges instead of what came with the artf.
My envision came out at 5083 grams, I plan on changing a few things including a R6008 Futaba rx instead of the 14 and a Yge 90 instead of the schulze 32.8. that should
bring me down to just over 5000, but I plan on buying the new lightened Falcon 21x14 as soon as F3a Unlimited has them back in stock. For motor I currently have the
Pletty 30-10 Evo installed, but will be evaluating wether I need to go with the 30-9 Evo or the Advance next year when I get some more flights on it.
I have about 6 trim flights in on the plane and the only mix I can think of right away is the 2% down elevator at low throttle.
If you need any other pics, let me know.
Simon
