RCU Forums - View Single Post - CA Models ENVISION
Old 11-18-2011 | 11:20 PM
  #113
Si-F3a
Default RE: CA Models ENVISION
Some More pics,
One thing added is a support at the front edge of the servo tray, It had a bit to much flex in it for my liking.
Oh and on the UC mounting, I marked out the inside of the fuse as you will see, had to open up the holes in the fuse a bit for the UC legs to fit through.
Feed the UC legs into the fuse and clamp from underside of leg to top of UC mount and then drill through both mount and leg together.
Take the legs out, open up the holes for the T-nuts to fit, ca the T-nuts to the leg and put it back in and bolt it up
Simon
ID:	1688418   Click image for larger version
ID:	1688419   Click image for larger version
