RCU Forums - View Single Post - Reverse G62?
Thread: Reverse G62?
Old 11-20-2011 | 11:25 AM
vertical grimmace's Avatar
vertical grimmace
Default Reverse G62?
So I am planning a project in my head, and I had a couple of questions. I really want to use a G62 and was wondering how hard it would be to reverse the rotation? I want to use the magneto as I prefer them to EI.
Also, the reason why is this aircraft will be a pusher. What I am thinking is if I reverse the rotation, then I can use a standard prop turned around. Am I thinking correct here or is that not right? The main reason for this is that it opens up prop choices in this size, as I never see pusher props made that big.
