RCU Forums - View Single Post - PT-19
Thread: PT-19
Old 11-22-2011 | 04:58 PM
DaveB
Default RE: PT-19
A tip or two to keep in mind when building the "Hog" bashed or otherwise.
1. Drill the holes in the former in which the wing dowels are fitted before building the fuselage. This will make fitting the wing much easier later on.
2. Remember a tail dragger version of the "Hog" requires longer landing gear wires for prop clearance which is not included in the kit.
3. Consider using 3/16" music wire for landing gear as the 5/16" wire provided is more prone to bending back from landing. (A wider landing gear block will be needed to accomodate 3/16" wire which is available from Sig).
Good luck,
DaveB
