RCU Forums - View Single Post - Pushrod Geometry
Old 11-25-2011 | 07:49 AM
jaka
Default RE: Pushrod Geometry
Hi!
You must have misunderstood where the elevator hing line is!
The elevator hing line is in the middle of the rear line on elevator picture drawn. If the control rod is 90 degrees to the servo arm center... and at the same time....rod is 90 degrees to the elevator hinge line ...the trows are equall!
The first picture is right!
