RCU Forums - View Single Post - Three line fuel system
Old 11-25-2011 | 07:29 PM
Ed
Default RE: Three line fuel system
" Is there any problem with using a tee in the fuel feed line on a two line system to fill thru as I am now? "
With a -T-, you are introducing 3 more potential air leak points, rather then a straight line to the Carb. Think about it. Another point is that some people use a filtered clunk. If you use a -T- with a filtered clunk, then you are putting unfiltered gas directly into the Carb line. To filter properly using a filtered clunk, you must use a 3 line system.
ed
