RCU Forums - View Single Post - Eagle Aviation One Design Build
Old 11-26-2011 | 10:31 AM
Tony Hallo
Default RE: Eagle Aviation One Design Build
I made two sanding jigs for radiusing the edges, I drilled a 7/16" hole through a piece of maple boom stick then split in two halves, one for 150 grit, the other for 220. It's about 6" long. I knock the edges off with a Master Airscrew plane then finish the rest with 150 then 220. I color the edge surface with the side of a pencil then sand until the pencil makings disappear.
ID:	1691571   Click image for larger version
ID:	1691572   Click image for larger version
