RCU Forums - View Single Post - set time on 4 stroke
Old 11-27-2011 | 07:43 PM
Gray Beard
My Feedback: (-1)
Default RE: set time on 4 stroke
You don't need to have the piston and rod installed. There is a timing mark on the thrust washer that has to be facing up and even with the casting mark. Now slide the cam in with the dot facing straight down at 6 oclock. Print out the file and tack it on your shop wall.
File Type: pdf
