 set time on 4 stroke >
Old 11-27-2011 | 11:39 AM
Default set time on 4 stroke
need to set time on 4 stroke
Old 11-27-2011 | 11:54 AM
Live Wire's Avatar
Default RE: set time on 4 stroke
Need more information on the ENGINE
Old 11-27-2011 | 12:28 PM
its a os 61 had to take cam out lifters stuck bad got the values working now but got to put back in time seene dot on cam but can not see dot on crank thanks butch
Old 11-27-2011 | 01:49 PM
bingo field's Avatar
http://www.osengines.com/manuals/
see if you can find your model listed and download the manual
unless this is the same one
http://www.rcuniverse.com/forum/m_25...tm.htm#2515075
Old 11-27-2011 | 03:03 PM
it just says find mark on cam and crank line them up but on 4stroke with cam out crank looks like worm gear no mark thanks butch
Old 11-27-2011 | 07:11 PM
My Feedback: (7)
If memory serves me correctly all you do is put the piston at top dead center then install the cam so that the dot lines up with the pushrod tubes.
Old 11-27-2011 | 07:27 PM
thank you alot
Old 11-27-2011 | 07:43 PM
My Feedback: (-1)
You don't need to have the piston and rod installed. There is a timing mark on the thrust washer that has to be facing up and even with the casting mark. Now slide the cam in with the dot facing straight down at 6 oclock. Print out the file and tack it on your shop wall.
File Type: pdf
Old 11-28-2011 | 03:26 AM
WTG GB!
Old 11-28-2011 | 08:48 AM
My Feedback: (-1)
I have been using this little book and telling folks about it for years. I bought it years ago when I sent in an OS .70 for service to tower. They told me they would test run it and let me know what was wrong before they did anything to it. I was sure it was the needle valve, I had flown the plane through a tree and the engine wouldn't run after that. Tower took it apart, let me know it was run lean, had bent parts and was going to cost me a couple bucks less then a new engine to have it repaired. I had them send it back to me, it was in the box but taken apart. Bought the book, assembled the engine and it still wasn't running correctly. Replaced the needle valv assembly and ran the engine inverted in a IMAA plane for three years without a dead stick. Last engine I ever sent in for repairs.
The book may still be printed?? A GUIDE TO OS 4 STROKES By Graham C. Rice and sold through the RCM Anthology Library?? It used to be sold in most hobby shops for just a couple bucks. You don't see a lot of Gudgeon Pins in newer engines but other then that it's still everything you need to know about most 4 strokes.
