RE: Engine Spitting FIRE!!! Help
It must have been manufactured after the date on the recall, because I bought the engine from Tower just 2 weeks ago.<div></div><div>It is worth noting that the cylinders and spark plugs seem really dry, as if the carburetor wasn't getting enough gas to them, but the reeds are perfect, or at least they look so, and when the engine is running, it does a good job. When taken to WOT, though, it seems to loose power after a couple of minutes, and then the throttle feels unresponsive when ratcheted to try to keep the engine running, and then it quits -this doesn't happen all the time, but it happens.</div><div></div><div>Again, thanks</div>
