ORIGINAL: rexbirk I am wanting to get rid of the *&##@ philips head servo arm screws and using socket head screws. In researching what size the screws are I am seeing people saying all different sizes. Looks like 2.5 or 2.6 by 8mm but which one?
Standard Machined Servo Screws 2.6mm x 6 mm or 8 mm Phillip-head (JIS) screws
Servo screws do not haveUSA style Phillips head screwswhich is why some USA users with ill fitting screwdrivers ream the heads out . Refer to:
<dt>
Servo - Horn Screw - Hitec & Futaba Metal & Resin gear screw sizes
Following will also assist:
</dt><dt>
Servo - Horn Arm Spline Count and Inter Brand Compatibility </dt><dt>
Servo - Horn Arm Extensions - DIY Alloy, FRP, CF & Nylon
Servo - Hitec MG Servo Output Shaft Size - Cross Hair Mark New </dt><dt>
Servo - Hitec Servo Nomenclature </dt><dt>
ex "Radio Systems, Accessories, Alterations and FAQ." at:
Alan's Hobby, Model & RC FAQ Web Links
</dt><dt>Alan T.
</dt>
