RE: YS 110s problem
Xmans.............<div>
</div><div>Thanks for your reply , could you please describe how in a little more detail. Presumably heat up the case, 'drift' the brass sleeve out a little enough to nip with fine pliers, re align with the outer brass nipple (15 past the hour, its 10 past at the moment) and tap back in. Can you remember how easily it is to turn and push back in?, any other clues will help. </div><div>
</div><div>
</div><div>regards Bob</div>
