RE: Prop size question
On 3S the 8x8x4 will draw slightly higher amps, you'll loose roughly 30% thrust, and gain 40% in prop speed.
If you could fit a 9x6x3, amps similar, thrust only slightly less, and prop speed slightly higher then the 10x3.8 set up.
