RE: Prop Balancing
Do you sand the face or the back when you balance your props? Also, what grit sand paper do you usually use.
I found a decent answer to my k-series prop question. It's perfectly alright to use k-series props on electric motors, but because of their weight it's recommended that you reprogram the esc for a soft start.
