ORIGINAL: chriz2388
The set up i have is using the stock esc and stock motors i just want to make sure i wont fry the esc by having to big of C rating or to big of mah. Also would it make a difference if i took the stock esc from an e-maxx and used that because i have an extra one.
MAH is just capacity of the battery, it won't affect the esc just longer runtimes. The "C" rating won't hurt it either, you get more punch with a higher rating.
But I would get a lipo cutoff to protect you from running the batteries too low. I also added one of those little low-voltage buzzers in case I missed the LVC they are under $5.
Can you add your water cooling to the e-maxx esc?
