Go Back  RCU Forums > RC Boats > Speed - Electric
 Villian ex esc help >
Villian ex esc help
Speed - Electric For all your electric boating needs.
Villian ex esc help
Old 12-02-2011 | 09:19 AM
Default Villian ex esc help
hi,
I have an older villian ex and the motors are starting to wear down but i have an emaxx that i am about to replace for a brushless set up. I was wondering if i can transfer the motors from my emaxx and the esc to the villian. I kno the old esc had water cooling would it overheat if i had it in the boat my reason for switching esc is cause i want to run 7 cell batts and the old esc is only rated for 14.4v and not the 16.8 that the emaxx esc is cabable of handling.
Old 12-02-2011 | 12:41 PM
Default RE: Villian ex esc help
THE 7 CELL BATTERY IS 2 HEAVY FOR THE VILLAIN EX,THE BEST BATTERY YOU CAN US IS [ 6 CELL 5000 7.2 VOLT NIMH FROM VENNOM ] I US THIS FOR MAI VILLAIN EX,AN BLACKJACK 26.....
Old 12-02-2011 | 01:24 PM
Ok i also have two lipos 2s that i know add up to 14.8 is that to much for the stock esc and if so can i replaced the non-watercooled esc for the stock ones in order to run the lipos.
Old 12-02-2011 | 02:11 PM
CAN YOU SEND ME A PHOTO OF YOU SISTEM FOR TH NEW UPGRATE IS OK ...
Old 12-02-2011 | 05:36 PM
I run 2 of these little tight fit but works great ! Stack them on top of each other.
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
Old 12-05-2011 | 08:05 AM
The set up i have is using the stock esc and stock motors i just want to make sure i wont fry the esc by having to big of C rating or to big of mah. Also would it make a difference if i took the stock esc from an e-maxx and used that because i have an extra one.
Old 12-05-2011 | 08:25 AM
Don't know about the E-maxx ESC but I run the stock motors and stock ESC with those batterieres.
Old 12-05-2011 | 10:13 AM
Tombsy's Avatar
ORIGINAL: chriz2388
MAH is just capacity of the battery, it won't affect the esc just longer runtimes. The "C" rating won't hurt it either, you get more punch with a higher rating.
But I would get a lipo cutoff to protect you from running the batteries too low. I also added one of those little low-voltage buzzers in case I missed the LVC they are under $5.
Can you add your water cooling to the e-maxx esc?
Old 12-05-2011 | 02:38 PM
Yes you can runemaxx esc; thats what I am using. Just have to take off the heat sinks and add the optional water cooling kit from traxxas. Only difference is that you dont have a mounted on/off switch. Im using stock 23t motors and 447's. I use two 4000mah 35c lipos. Just changed the set up. Here in Nor-Cal been very windy and havent be able to get to the lake yet...
I have a set of emaxx21t 550... would that make a difference?
Old 12-05-2011 | 03:00 PM
Tombsy's Avatar
It should make a difference, maybe drop a pinion size and check the temps after a run.
I tried the Monster Maxx motors, I think they were the 19t's, man I dropped 2 gears on the pinion and they still got so hot they melted the wires off the motor! (with water cooling)
I've never seen a motor burn up brushes like that either. (I was running 14 nimh cells)
I've gone back to stock motors and props now because I'm using it for a rescue boat. But it's sure nice to use my lipo's in it now. I'm using the Turnigy 5000 and 6000mah batts as well.
Old 12-05-2011 | 03:45 PM
Well, i have them and they arent doing anything... Im gonna check out current set-up, then switch. i will let you know
Old 12-06-2011 | 08:04 AM
Thanks for the info but i heard that you can not get lipo batts wet and i have a small leak somewhere and sometimes water gets in not alot but enough to reach where the batts sit in the hull is there a way to waterproof them?
Old 12-06-2011 | 10:16 AM
I put my lipos in a lunch bag. my boat gets water in it too, from the hatch that isnt sealing to well.
Old 12-06-2011 | 11:03 AM
Tombsy's Avatar
I've been taping the hatch with hockey shin pad tape. I use reverse a lot using it for a resue boat and it's kept it dry.
And you can put a piece of Sham-wow in to soak up what does get in.<br type="_moz" />
