RCU Forums - View Single Post - CJM F-4D Conversion and Build
Old 12-05-2011 | 07:50 PM
USSCAT's Avatar
USSCAT
Default RE: CJM F-4D Conversion and Build
Now, it is time for putting the wing skin on using nothing but Gorilla Power, this stuff really works, the only problem was that the bottle would dry up after a couple of times till someone here on RCU had a genius idea to store the bottle upside down so the top portion of the glue (bottom side) would dry but the top would stay fresh and usable.... Thankyou whoever you were.
I wet both surfaces and applied the glue to both side and then pulled vacuum about 18 In Hg. worked like a charm.
ID:	1695921   Click image for larger version
