Hello All,
I have a Slow Stick with the EPS-300C power unit on it. I am new to rc flying and have played lawn dart with my plane a few times. In the last crash it hit hard enough to break the motor mount, prop and bend the drive shaft at about a 45 degree angle. I saw that horizon has some parts on their web site but they don't list what goes to what. My question is can anyone tell me if the drive shaft part no. GWS6A is the correct one for the plane and what gear ratio motor kit is the correct one or if a different one is better? Also what motor mount is the correct one? And is the gear puller really needed? If so which one is the correct one for the EPS-300C? Or should I get an EDP-400C system it looks like it is direct drive and held in by a rubber band so I would think it is less likely to break. Would weight and run time become an issue with that motor.
On my last flight I actually got 5 minutes of air time in before I crashed. Whoo Hoo
Patrick
