ORIGINAL: The Hedgehog
ORIGINAL: cumminspower5.9
well to answer most everyone as of now starting from the top.
-yes, sheo, this does happen every winter.
-hedgehog, 2 psi below max doesn't mean it's going to blow out the tire. max is just max recommended psi, ive seen tires go above that for years.
-proanti and dave, i had only replaced the paper filter with the K&N. i don't have the actual cold air intake on this car. i know it would be pointless. i let the car warm up every morning.
i drive like an old man as well because i know it uses more fuel. plus why not get the most out of the expensive liquid.i try not to let the engine get above 3200 rpm.
Max recommended tire pressure is different than max tire pressure. You never clarified which.
ok. the tires are set at 2psi below what the sidewall reads.
