RE: Dual servos on elev
You do have dual elevator capability with the RD8000. You must be out of Basic and use the Advanced Menu Structure. See Page 32 of your RD8000 manual. To obtain Dual Elevators select the etc menu. Scroll down to D-EL and make it ACTive by pressing either the INC or DEC key. Output will be on Channels #1 and #7. Each of the channels can be individually adjusted for Reverse, Center and EPA. Both operate together with the Elevator stick. Call if you need further assistance.
AIRTRONICS TECHNICAL SUPPORT
800-262-1178
