RE: pull/pull wire crossing
I think that the point most people miss when the set up a pull pull system is that they do not allow for a little positive Ackerman. Having the non pulled line go a bit slack is an advantage, not a disadvantage. And yes, most set the line up much to tight, you want them just tight enough to not droop at neutral.
