ORIGINAL: David Bathe
...Control horn/conection point width must be identical to the servo hole width or visa verse.
Use a screw adjustable horn(s) at the controll surface end and adjust it so its Identical to the servo arm width.
If the geometry is good and the control horn holes align with the hinge line, the control horn length does not have to be the same as the servo horn.
Kurt
