RE: CJM F-4D Conversion and Build
It is time for setting the wing box for the fuse. I used the plan and cut two Ribs, similar to the one on the end of the wing and squared them with respect to each other and installed it in to fuse and attached to the main formers. The main formers had to be modified a bit, added an extension to the ends to accommodate attachment to the wing box.
