Todd,
My vote also goes to the DB (discounting my login name
) Both are excellent planes, but the DB's wing is slightly thinner making it penetrate the wind slightly better. As Dave mentioned, the landings can be a little hotter, unles you bleed off airspeed sooner. Although this helps if your approaching a head wind while landing. Watch the CG on the DB, being sure to keep it per instructions. Should it go slightly tail heavy, you may experience difficulty getting out of a flat spin, [X(] although it does a flat spin very well.
