RCU Forums - View Single Post - G-23 idle issues
Old 12-14-2011 | 08:10 AM
w8ye's Avatar
w8ye
My Feedback: (16)
Default RE: G-23 idle issues
The front seal should not be leaking.
A leaking seal will cause hard starting and needle valve adjust ment problems.
You would have to do a crankcase vacuum/pressure test to see if the seal is leaking.
Might try a little oil around the front hub?
