G-23 idle issues
Old 12-13-2011 | 04:30 PM
My Feedback: (28)
Default G-23 idle issues
I have a g-23 that when I got it 8 yrs ago would idle like a sowing machine.
Now after a 5 min flight at 3/4 she wants to die at idle.
Also the front seal squeaks when I rotate the prop just after a run.
Just rebuilt carb and running 30:1 with 92 octane and fuel treatment for ethanol.
Help!!!!
Old 12-13-2011 | 05:04 PM
Default RE: G-23 idle issues
Sounds like it might be a bit too lean on the low needle, so try richeneing it just a bit.
Karol
Old 12-13-2011 | 05:29 PM
My Feedback: (28)
Tried that. Made the idle worse.
But thanks.
Old 12-13-2011 | 06:20 PM
Try some good gas...forget the fuel treatment. Capt,n
Old 12-13-2011 | 06:52 PM
My Feedback: (28)
The gas I was using wasnt old. But not new either.
I'll give it a try. And will leave out the treatment.
Thanks.
Old 12-13-2011 | 08:21 PM
ORIGINAL: sgtshultz
Thanks.
Some brands of gasare better than others. Try Penzoil 2 cycle oil (30-1) for air cooled engines too. Good Luck Capt,n
Old 12-14-2011 | 06:18 AM
What size prop are you using and what is the idle rpm.
Karol
Old 12-14-2011 | 06:28 AM
My Feedback: (28)
16x6 top flight
About 2,600 to keep it from quitting.
Old 12-14-2011 | 06:34 AM
w8ye's Avatar
My Feedback: (16)
It will idle better with the plug gap a little great than .5mm. Try .6mm or .024"
Old 12-14-2011 | 06:39 AM
I use a Dynathrust 16/8 on my older G23, and idle below 2000 rpm. You may want to try a heavier composite (MA or ACP) prop over the wood one you are using. I also use Coleman's lantern fuel and Pennzoil 2 cycle aircooled oil at 32:1 with no treatment added or needed; fuel lasts forever. Many will argue against the use of low octane Coleman fuel, but the G23 is low compression and does not need higher octane.
Sincerely, Richard/Club Saito #635
Old 12-14-2011 | 07:02 AM
Like Spaceworm suggested, I too use a 16x8 prop on my G23 which is run on 87 octane pump gas / Redline oil mixed at 32:1 and the engine idles at about 2,000 rpm.
Karol
Old 12-14-2011 | 07:24 AM
My Feedback: (28)
Thanks everyone. I'll be giving it a try.
Old 12-14-2011 | 07:25 AM
My Feedback: (28)
Any thought about the front shaft seal squeaking right after a run?
Old 12-14-2011 | 08:10 AM
w8ye's Avatar
My Feedback: (16)
The front seal should not be leaking.
A leaking seal will cause hard starting and needle valve adjust ment problems.
You would have to do a crankcase vacuum/pressure test to see if the seal is leaking.
Might try a little oil around the front hub?
Old 12-14-2011 | 08:18 AM
My Feedback: (28)
No leaking. Just squeaking.
Old 12-14-2011 | 09:15 AM
During the 8 years was the engine in constant use or was it in storage. If it was not in use maybe the seal is just a bit stiff from aging. The good thing is that it is not leaking, that's the Zenoah quality talking.
Karol
Old 12-14-2011 | 09:51 AM
soarrich's Avatar
My Feedback: (98)
ORIGINAL: sgtshultz
You may have a fornt bearing that's going bad. It sounds like it heats up and gets tighter durn the flight.
Old 12-14-2011 | 10:24 AM
My Feedback: (28)
Thanks. But it really sounds like rubber rubbing against the hub.
Old 12-14-2011 | 12:36 PM
2 things come to mind. The diaphragm in the carb seems to not be set up correctly. Also if you had a recent crash or propellor strike it is possible the shaft is bent. Either way I would ask Antique. He is the best when it comes to Zenoah engines. If there is any friction on the hub other than when the piston comes up on the compression stroke something is wrong. Again ask Antique.
Regards
Glenn Williams
Old 12-14-2011 | 12:49 PM
Apply some silicone spray to where the shaft and seal meet. You may need to do that a few times. The sound or squeal should then go away. Capt,n
