RE: Lazy Bee's??
Any upates guys?
I just recently got 2 of the(foamy) COX lazybee`s,(used,ebay) sounded a lot simpler that building...............well then again, theu are used right?
Well at least they were cheap!!
So the first has a badly warped wing, I`m lookingup plans to see about using a bult up wing in its place, chord is about 13 7/8" x 38" span
The second just arived today, fuse isin great shape,but the wing ( OH,NO, not again)..........well someone didn`t like all the white foam apparently,and decides to spray paint the wing!! yes, you guessed id, not using foam safe spraypaint!! luckily they statred at the trailing edge with the paintjob, and stopped when the foam started showing deterioration lol
I`m tempted to just monokote that wing and try it out.
As is, its not/ish terribly deformed butlift and aerodynamicsare def. going to be affected by the coarse tinybubbling;a little worse than 50 grit sand paper for the most part.
