ORIGINAL: TheBennyB
I guess this means for all the people using the Lansu TX and RX, don't break your TX or fry your RX cause you'll have to order both not
just the one you busted up.
where did you find the info on the binding process then?
Is there maybe a different button you should press on the Tx before you turn it on?
Im not totally surprised that noone at redcat knew if it could be done, but i cant imagine a 2.4system that can be bound to other rx's of the same make.
