RCU Forums - View Single Post - Alpha wing
Thread: Alpha wing
Old 08-26-2003 | 12:27 PM
danny03's Avatar
danny03
Default Alpha wing
The damage that is on the right wing, can you cut it out completely, leaving you with either 1 or 2 good sections. if so cut back to the nearest rib so that you can trace the rib pattern to scratch build(repair), then add the appropriate LE and any formers or sheeting. This should be less expensive than buying another wing. Good luck and may you have a speedy recovery....
