spitfire fuselage
Andy, the Uiberlacher MkXVI plans should work for you as the fuselage is the same between the firewall and the vertical fin. Just need to scale it down to 69 inches to fit your project. I can scan the fuse sheet of my plans and send you an electronic file if that will work for you.
Dave, thanks for the offer but I've got way too many other projects to invest in right at the moment.
