RE: Ignition Ground Wire
If the ignition has shielded leads the ground is in the braid....If not the spark is going through the sensor and it will soon be gone...
Had an old C&H years ago that someone grounded the ignition through the carb mounting bolts into the bakelite carb insulator block...The C&H is good enough to make a carbon track through the bakelite to ground, and the engine still ran...
another with a broken ground wire was a Q52...You could see the spark at the gap between the sensor and the hub with the engine running...They don't make hall sensors like they used to, or ignitions either....
