RCU Forums - View Single Post - Eagle Aviation One Design Build
Old 12-22-2011 | 05:17 PM
Tony Hallo
Default RE: Eagle Aviation One Design Build
Let the wing construction begin. The wings will be foam rib construction. About 20 years ago I made this jig to build a Urley 33% Laser. The ends have sagged over the years so before beginning I added 2'X4'x5/8" particle board to the top. This really increased the weight but it is flat now. The jigs are made to bolt together to allow the wing tube to be cut at the same time in both panels. The wing tube centerline is layed out from tip to tip. Parting stock is use to retain the foam blanks in place per plan spacing. The strips are held in place with braids.
I normally use 1/2" thick blue foam with 5" rib spacing, the plans show slightly less than 4" spacing so I plan to reduce the 1/2" foam to 3/8" to keep similar weight construction.
List of planes build using this jig;
33% Urley Laser
33% Extra 230 (Modified ACE design)
33% Godfrey Extra 300
33% Extra 200 (Tony Design)
35% Hurley Extra 300 LX
38% Godfrey One Design
38% Eagle Avaition One Design
ID:	1703769   Click image for larger version
