soldering cable ends
I tried to solder cable ends that go into coupler. Reason so set screws don't ruin the cable ends. I read somewhere to solder the ends will stop the wear and tear. I tried using plumbing pipe ends and turned up zilch. I had the solder melted in plumb. end and was hot enough to burn paper but didn't work. I searched OSE and google and ping but no luck. Any help would sure help. Have a good day! Thanks!
