ORIGINAL: choihjin
It is amazing, it works.
My dead DLE 20 gas engine is revived with gas/glow conversion. This DLE 20 engine fall down with signal loss. I guess the signal loss is due to the ignition noise even though this plane has been flown for many hours. The ignition power is supplied from Hitec Optima receiver. Many, that time, said that 2.4 GHz receivers are safe from a ignition noise. After signal loss, I conclude that the cause is ignition noise which affected the receive malfunctioned. During flight, throttle channel did not work, but all other channels were working, then I lost whole channels. The plane with high speed running engine crushed fortunately onto soft mud. The plane fuselage, receiver, fuel tank, ignition, spark plug and servos were scattered away, but the engine apparently looks fine. I took out it from deep mud and cleaned. Now I am testing with OS F plug on CM6/OS F plug conversion kit, and fueld with Gas/Glow mixture. Thanks a lot for fujiman who supplied the conversion kit to me, and all other developers in this forum.
Seeing is beleaving:
http://youtu.be/N3Aspe8Tbe0
Regards to all gas/glow conversoners
thanks choihjin for your kind words regarding my plug adapters i made and sent you!!!!!! i'm so happy they worked so well for you! sorry about your plane tho! i'm happy to see that the dle 20cc puts out more power on gas/glow fuel, it will encourage more guys to go that route!
thanks again for your kind words and your business!!!!! fujiman (SPIN-TRU LATHE & MILL)
