RCU Forums - View Single Post - Reducing weight 4*60 tail
Old 12-31-2011 | 07:27 AM
JohnBuckner's Avatar
JohnBuckner
Default RE: Reducing weight 4*60 tail
Yes I have done so on many airplanes but mostly old timer types. As the others seem to have hinted at, its often for very little gain especially on that type airplane.
If you are doing this to help with a CG problem (CG to far aft) Then here is a very effective method that simply moves the battery forward along side or under the engine and invloves no adding of lead.
John
ID:	1707617   Click image for larger version
