RE: Rocket launch by Raptor 50!!!
AMA does not allow rocket to leave the aircraft. You can use rocket motors to lift the aircraft. There used to be a rocket powered glider. It was lifted up by the rocket motor. You can use them as rocket assist take off too. The rule says the rocket motor must be kept on the aircraft.
Yet that is only at AMA sanctioned fields. AMA does not cover when flying out in the deserts where I fly.
Buzz.
