Rocket launch by Raptor 50!!!
see the awesome video of a system of radio controlled rocket launch
http://www.youtube.com/watch?v=vwkEIKnLFPA
ORIGINAL: blvdbuzzard
AMA does not control another countries R/C rules, so it does not violate the AMA rules.
Buzz.
Buzz.
Vinicius</p>
AMA does not allow rocket to leave the aircraft. You can use rocket motors to lift the aircraft. There used to be a rocket powered glider. It was lifted up by the rocket motor. You can use them as rocket assist take off too. The rule says the rocket motor must be kept on the aircraft.
Yet that is only at AMA sanctioned fields. AMA does not cover when flying out in the deserts where I fly.
Buzz.
Buzz.
