RCU Forums - View Single Post - Throttle cable sig se
Old 01-03-2012 | 03:39 PM
SeamusG's Avatar
SeamusG
Default RE: Throttle cable sig se
The 1st pic is of my 2nd SSE- built to the manual without any mods. The 2nd is of my last SSE- as I was using a mini servo it fit nicely in front of the fenolic tube. Btw, the role of the phenolic tube is to serve simply as a bushing for the wing tube. It has no structural role - this is per Mike the designer.
About using a cable - unless the run is straight it is my #1 choice for the throttle linkage as it can be routed around the fuel tank as necessary.
ID:	1709328   Click image for larger version
